title: Improved Performance Through AWS Enhanced Networking
description: Find out how the latest addition to the ONTAP 9.4 release for Cloud Volumes ONTAP can improve storage performance with the support for AWS enhanced networking.
image: https://cloud.netapp.com/hubfs/Improved%20Performance%20Through%20Cloud%20Volumes%20ONTAP.png
![NetApp-Blue-logo-sm1](https://bluexp.netapp.com/hubfs/NetApp-Blue-logo-sm1.svg "NetApp-Blue-logo-sm1")
![hamburger icon](https://bluexp.netapp.com/hubfs/NetApp-Blue/hamburger-icon.svg) ![close icon](https://bluexp.netapp.com/hubfs/NetApp-Blue/close-icon.svg)
- Product
  ![left nav icons-1](https://bluexp.netapp.com/hubfs/left%20nav%20icons-1.svg)Storage
    - [NetApp On-premises](https://bluexp.netapp.com/netapp-on-premises)
    - [Cloud Volumes ONTAP](https://bluexp.netapp.com/ontap-cloud)
    - [Amazon FSx for NetApp ONTAP](https://bluexp.netapp.com/fsx-for-ontap)
    - [Azure NetApp Files](https://bluexp.netapp.com/azure-netapp-files)
    - [Google Cloud NetApp Volumes](https://bluexp.netapp.com/google-cloud-netapp-volumes)
  ![data mobility](https://bluexp.netapp.com/hubfs/NetApp-Blue/data-mobility.svg)Mobility
    - [Copy and Sync](https://bluexp.netapp.com/cloud-sync-service)
    - [Tiering](https://bluexp.netapp.com/cloud-tiering)
  ![left nav icons-2](https://bluexp.netapp.com/hubfs/left%20nav%20icons-2.svg)Protection
    - [Backup and recovery](https://bluexp.netapp.com/cloud-backup)
    - [Disaster recovery](https://bluexp.netapp.com/disaster-recovery)
    - [Replication](https://bluexp.netapp.com/replication)
    - [Ransomware protection](https://bluexp.netapp.com/ransomware-protection)
  ![left nav icons](https://bluexp.netapp.com/hubfs/left%20nav%20icons.svg)Analysis and control
    - [Observability](https://bluexp.netapp.com/cloud-insights)
    - [Classification](https://bluexp.netapp.com/netapp-cloud-data-sense)
    - [AIOps & storage health ](https://bluexp.netapp.com/digital-advisor)
    - [Digital wallet](https://bluexp.netapp.com/digital-wallet)
- Resources
    - ![solutions database](https://bluexp.netapp.com/hubfs/NetApp-Blue/solutions-protection.svg)CALCULATORS
    - [TCO Azure](https://bluexp.netapp.com/azure-calculator)
    - [TCO AWS](https://bluexp.netapp.com/aws-calculator)
    - [TCO Google Cloud](https://bluexp.netapp.com/google-cloud-calculator)
    - [Cloud Volumes ONTAP Sizer](https://bluexp.netapp.com/cvo-sizer)
    - ![resources explore](https://bluexp.netapp.com/hubfs/NetApp-Blue/resources-explore.svg)EXPLORE
    - [Global Availability Map](https://bluexp.netapp.com/cloud-volumes-global-regions)
- [Help Center](https://bluexp.netapp.com/help-center)
[Get Started](https://cloudmanager.netapp.com/)
# Improved Performance Through Enhanced Networking Support in Cloud Volumes ONTAP on AWS
### Share
[![Facebook](https://bluexp.netapp.com/hubfs/Facebook.svg)](https://www.facebook.com/sharer.php?u=https://bluexp.netapp.com/blog/improved-performance-through-aws-enhanced-networking) [![Twitter](https://bluexp.netapp.com/hubfs/Twitter.svg)](https://twitter.com/share?url=https://bluexp.netapp.com/blog/improved-performance-through-aws-enhanced-networking) [![LinkedIn](https://bluexp.netapp.com/hubfs/linkedin-1.svg)](https://www.linkedin.com/shareArticle?mini=true&url=https://bluexp.netapp.com/blog/improved-performance-through-aws-enhanced-networking)
### Subscribe to our blog
Thanks for subscribing to the blog.
### August 7, 2018
### Topics: [Cloud Volumes ONTAP](https://bluexp.netapp.com/blog/topic/cloud-volumes-ontap)[Cloud Manager](https://bluexp.netapp.com/blog/topic/cloud-manager) [AWS](https://bluexp.netapp.com/blog/topic/aws)[Master](https://bluexp.netapp.com/blog/topic/master)[2 minute read](https://bluexp.netapp.com/blog/topic/2-minute-read)[Performance](https://bluexp.netapp.com/blog/topic/performance)
If you haven’t heard the news, NetApp ONTAP Cloud has been rebranded as NetApp Cloud Volumes ONTAP. Along with the change comes exciting news of the release of support for [ONTAP 9.4](https://docs.netapp.com/us-en/cloud-volumes-ontap/reference_new_94.html) – which in Amazon brings significant increases in front end performance. How cool is that, for once something really is both “New and Improved.”
The most significant addition to the ONTAP 9.4 release for Cloud Volumes ONTAP is the inclusion of support for enhanced networking for the software defined storage system. As described by Amazon:
![Cloud Volumes ONTAP increases front end performance](https://cloud.netapp.com/hubfs/Cloud%20Volumes%20ONTAP%20increases%20front%20end%20performance.png)“Enhanced networking uses single root I/O virtualization (SR-IOV) to provide high-performance networking capabilities on [supported instance types](https://docs.aws.amazon.com/AWSEC2/latest/UserGuide/enhanced-networking.html#supported_instances). SR-IOV is a method of device virtualization that provides higher I/O performance and lower CPU utilization when compared to traditional virtualized network interfaces. Enhanced networking provides higher bandwidth, higher packet per second (PPS) performance, and consistently lower inter-instance latencies. There is no additional charge for using enhanced networking.”
Keep in mind that there are two types of enhanced networking interfaces supported by AWS and that NetApp supports at present the former (VF).
1. Intel 85299 Virtual Function (VF) interface which is supported within Xen hypervisor
2. Elastic network adapter supported from within KVM
The following graph calls out the increase in performance introduced by upgrading from ONTAP 9.3 to ONTAP 9.4 on an active-passive HA pair based on the c4.8xlarge instance type. Using the SLOB2 workload generator and Oracle 12.2c, we performed a 75% read 25% update workload using an 8K database block size. While the read I/O rate increased 25% simply by upgrading a Cloud Volumes ONTAP cluster, the latency reduction is even more impressive.
![NetApp Cloud Volumes ONTAP Running in HA Configuration](https://cloud.netapp.com/hubfs/NetApp%20Cloud%20Volumes%20ONTAP%20Running%20in%20HA%20Configuration.png "NetApp Cloud Volumes ONTAP Running in HA Configuration Screenshot")
The upgrade path from ONTAP 9.3 to ONTAP 9.4 is a breeze with [the Cloud Manager.](https://bluexp.netapp.com/blog/hybrid-cloud-storage-management-with-oncommand-cloud-manager) The Cloud Manager takes care of everything from upgrading the Cloud Volumes ONTAP nodes without downtime (assuming your environment is running in an HA configuration) to enabling sriov-net-support on the instances. It's as simple as clicking on the “New version available link” below and checking yes on a few “I have read and acknowledge the above.”
![NetApp Cloud Manager Screenshot](https://cloud.netapp.com/hubfs/NetApp%20Cloud%20Manager%20Screenshot.png "Cloud Manager NetApp")
Not all instance types support enhanced networking. Cloud Manager can help you there too by showing which instance types support this enchantment (those with the lightning bolt as shown below) as well as managing the process of instance type change in case you are interested in such. As the upgrade process, instance type change may be performed non-disruptively if running in an HA configuration.
![NetApp Cloud Volumes ONTAP Premium AWS Screenshot](https://cloud.netapp.com/hubfs/NetApp%20Cloud%20Volumes%20ONTAP%20Premium%20AWS%20Screenshot.png "NetApp Cloud Volumes ONTAP Premium Screenshot")
[![New call-to-action](https://no-cache.hubspot.com/cta/default/525875/e19edfe1-83be-4cf9-a058-ee0e5ebae0e9.png)](https://cta-redirect.hubspot.com/cta/redirect/525875/e19edfe1-83be-4cf9-a058-ee0e5ebae0e9)
[Chad Morgenstern](https://bluexp.netapp.com/blog/author/chad-morgenstern-senior-cloud-solutions-architect-netapp-cloud-data-services)
### Senior Cloud Solutions Architect, NetApp Cloud Data Services
<https://bluexp.netapp.com/blog/author/chad-morgenstern-senior-cloud-solutions-architect-netapp-cloud-data-services>
```json
  "@context" : "https://schema.org",
  "@type" : "TechArticle",
  "author" : {
    "@type" : "Person",
    "name" : "Chad Morgenstern, Senior Cloud Solutions Architect, NetApp Cloud Data Services"
  "dateModified" : "Aug 7, 2018 5:46:11 AM",
  "datePublished" : "Aug 7, 2018 5:46:11 AM",
  "description" : "Find out how the latest addition to the ONTAP 9.4 release for Cloud Volumes ONTAP can improve storage performance with the support for AWS enhanced networking.",
  "headline" : " Improved Performance Through Enhanced Networking Support in Cloud Volumes ONTAP on AWS ",
  "image" : [ "https://cloud.netapp.com/hubfs/Improved%20Performance%20Through%20Cloud%20Volumes%20ONTAP.png" ],
  "mainEntityOfPage" : {
    "@id" : "https://bluexp.netapp.com/blog",
    "@type" : "WebPage"
  "publisher" : {
    "@type" : "Organization",
    "logo" : {
      "@type" : "ImageObject",
      "url" : "https://bluexp.netapp.com/hubfs/2016_dev/netapp-logo.png"
    "name" : "Netapp"
